John Robinson
Gone but not forgotten
Finally got the ECM and the car would not run. Finally out of desperation they took off the air cleaner and sprayed carb cleaner in the inlet. The car caught and backfired but when it did that it also showed power to the injectors. Cranked engine and it ran but with a high idle. What it all came down to was the Throttle Position Sensor. It was shutting off the injectors because it believed the engine was flooded. In that scenario it thinks you are at wot trying to clear the cylinders and so it shuts off the fuel. I will picking up the car in a few min. I will let you know if it is running well. Thanks to all you great people who responded to my need. I hope this information will be helpful to others.
