06ZO6 said:I did not notice much difference changing just the bulbs. Upgrading to the PIAA 1100x made a world of difference. In fact, they throw off better light than my headlights. True that they are bright, but as low as my car sits, I find that I blind few drivers.![]()
Mike
silver98 said:Not to hijack this thread, but my 98 was not ordered with the $15 option to include fog lamps. Is the wire harness already there? Can I add after market fogs without a lot of crazy drilling, cutting, welding, sawing, primping, painting, cussing and drinking?:confused :L
Terry Holtz said:Ok..... Where is the best (cheapest) place to get some PIAA 1100x's?
98TXRed said:Stosh, with all these helpful comments, I don’t know if you picked up what Vettex2 was saying, but you can replace the existing bulbs, and no modifications to the assembly, with Sylvania 885 (50 watts) bulbs. You can get them at any Walmart or automotive shop and they are easy to replace, just be careful no the touch the new bulbs with your fingers.
fdxpilot said:I agree with the 885s. They are the stock foglight bulb on 93-97 Camaros and are 50w vs 37w for the C5 stock. Also, checking the aim on your lights is a big help. Mine were pointed down at quite an angle. I re-aimed them to be just below the low beams.
Yeah, they are. I put a set of those in my Tahoe as well. The light cast is much "whiter" (is that a word?)98TXRed said:Are the Sylvania Silverstar Bulbs a direct replacement with the OEM headlight bulbs?
