norvalwilhelm
I decided to upgrade my hydraulic emergency brake/ not parking brake with twin master cylinders. I fell it was easier to hook up individual lines then Tee one line and at the same time if one master cylinder failed I would still have the other one.
It is easy to modify the stock emergency brake handle to activate a hydraulic master cylinder or two in this case.
Handle feel is also like stock, smooth and feels right.
This is the dual master cylinders mounted on an aluminum plate as a unit.
This is the calliper. It is a very light weight aluminum calliper with 2 live 2 inch pistons.
Hopefully it will actually serve as a emergency brake and stop the car from speed.
The car is away until next April so other then trying to move the wheel there will be no testing until then.
I would never trust a hydraulic system as a long term parking brake but it should function well as an emergency brake since it is operating on a 12 inch rotor.
