twiget
I discovered that the water pump is leaking coolant onto the opti-spark. So the water pump and opti-spark get replaced. I'd like to put an electric water pump in, and an upgraded ignition system.
There is also a ticking sound comming from under the left valve cover. It varies with the engine RPM, so I'm thinking worn lifters? What do I look for to indicate worn lifters. While I'm in there I would like to get more hp, so what would be the recomended mods? Rockers, valve springs, lifters, pushrods?
Jason
Jason
