XtremeVette
Iam wondering if its worth upgrading the ignition system of my 1990.
I have seen performanace distributors in Mid America and Ecklers that claim they double or give 50,000 volt sparks. Logic would suggest this would be better yes? or is this very misleading and is just snake oil as far as performance gains go?. I have two reasons for wanting to do it. I have somewhere in my ignition system something thats not quite right and prevents the car from starting. I twiddle with things then all of a sudden it fires up. Iam guessing its the small brittle wires that come out from under the distributor (they connect from the ignition module to the distributor). So by upgrading my distributor, I do believe Iam getting everything. New distributor, cap, rotor, upper coil and lower pickup coil, ignition module and the small wires.
Plus the advantage of more spark.
So does it sound worth it or should I just stick to what I have and see if I can't troubleshoot the wires.
Just trying to understand the voltage thing with the HEI distributors.
Jeff
Jeff
