7
72-LT1
Hey guys, I was just reading the vacuum questions here. I posted a question on the other site on this subject and still do not think it has sunk in.
My carb still has the vacuum hose running from a T at the front of the carb through the chock and down to the TCS and then to the dist.
If I want to eliminate the TCS can I just come right off that T and go to the Dist?
This whole question came up for me as I was adjusting the points and the timing, i'm only getting around 36deg total initial and mech adv because I can't test or run it while getting the vacuum advance kicked in.
After I gaped the points the car sure seemed to run better and the stumble seems to be gone. When I checked the gap there did not seem to be any or very small like .003 but the car was running pretty good it just had a stumble from a stop. Will these cars seem to run and idle OK with the gap being off?
