KikiPhillips
Ok....I borrowed a "Vacuum Puller" from my Dad, You hook an air compressor to one side and it draws 29.9 on the other end. I used it to test each of the 4 vacuum lines on the A/C control switch inside the car and everything open correctly.
So, I checked my source, from the little T connector where one end is connected to the Intake and the other goes to the vacuum cannister in the very front between the headlight actuators. And it is not drawing at all from the cannister. My headlights open and close properly but there is nothing drawing on that one line....
Any ideas or tricks to test, without replacing that cannister??
