Vacuum hose ends where?
  • Thread starter Thread starter UB2 SLOW
U
UB2 SLOW
The vacuum hose that exits the cruise control module and goes under the ECM towards the rear of the car ends where? The manual does not say and I cant find it? I need to replace this hose. Any help would be great.
On an '87 it goes to the switch above the brake pedal.
Don't know if it's the same on a '96 but it probably is.
Cruise Vacuum
The vacuum hose goes behind the engine to this vacuum valve. You may find that the valve has broken off the connectors. The good news is if that is the case the replacement part is under $10.:beer
Still here. I am still putting my car back together. The other hose ran into the firewall and then under the dash. I finally got it replaced today. I almost have the car back together and then its time for a test drive.
