Spinman
- Joined
- Oct 30, 2003
- Messages
- 30
- Location
- Cleveland, Ohio
- Corvette
- 1990 C4 L98 Coupe (original owner)
Just finished replacing my injectors and reassembling the engine.
Have a question on the vaccum hose for the FPR.
I see that there are 3 vacuum port on plenum, near the sensor that is mounted on the rear passenger side. The rear port has a hose running directly to the sensor (I never needed to remove).
That leaves 2 open ports (center and front). Which port does the line from the FPR attach to? The bend on the front port seems a little tight - so I am guessing that the middle port is the correct option (and presumably does not make a difference, vacuum is vacuum).
And finally, I must be missing a hose - what attaches to the 3rd (presumably front) port? BTW - my HVAC now blows only on the floor and defroster (default), so it would appear that I am missing a vacuum line for the HVAC system. I see that there is a pre-formed vacuum line running to a "T" on the drivers side of the firewall - and disappears under the fuel rail. Looks like I've pinched it under the rail. Rather than unbolting and freeing the line, perhaps it would be easier to just replace it. Does this hose then mount in the front vacuum port?
Thanks -
Thanks -
