Vacuum line
  • Thread starter Thread starter WVAVI8TOR
W
WVAVI8TOR
Is the vacuum line under the battery obvious or do you have to dig around for it. I suspect that is duct position problem I have with the AC/Heating system.
thanks
dusty
HI there,
It will run from the vacuum canister on the frame rail, into the wiring harness loom.
I would simply follow it from the canister till you find your break.
Allthebest, c4c5:hb
