- Thread starter
- #21
R
Roy
Electric Headlight Actuators
Chris,
I don't mean to rain on your parade, but you might want to conduct a quick poll of how many Corvette owners would buy your proposed electric replacement to the stock vacuum system. I see polls all the time on this site so why not a pre-marketing poll? You aren't trying to sell anything at this point, only determine feasibility.
The Corvette vacuum system is reliable and easy to understand if you take the time to walk through it. I used to dread the multitude of vacuum hoses under the hood and behind the dash, but once I spent an afternoon replacing every vacuum and fuel line, I was amazed at the simplicity of it all.
Besides, the vacuum system will usually fail slowly and not instantly like a blown fuse on an electrical system. The liability of having an accident resulting from an electric headlight system that unexpectedly failed is something you should consider. Besides the patent application, you may also need DOT approval as it is a safety item you are proposing.
The headlight vacuum system also provides a warning and indication of the health of the engine and/or other components connected to the vacuum system. If anyone experiences slow opening headlights or sluggish operation of any vacuum component, chances are that there is either a leak in the vacuum system and hoses, the heater control valves (especially the under the hood one that controls the hot water flow to the heater core) the carberator or carberator base, the intake manifold or a few burnt cylinder head valves.
So think of the vacuum system on the Corvette as your friend and when it starts to act up, it is trying to tell you something. You can order color coded hoses and schematics for $$$ or simply buy quality rubber vacuum hoses from your local auto supply store $15) and spend an afternoon replacing the hoses one at a time. By the way, there are several hoses that you can eliminate which will clean up things under the hood. E-mail me if you would like a list.
One last point ... when you buy replacement vacuum hose, be sure to get the correct ID. Some folks install hoses that feel o.k. and they slip on and off easily. Vacuum hose comes in ID sizes of 1/32 increments, so be sure that your hoses slide on snug and can't be accidentaly pulled off. Spit on the inside of the vacuum hose always works well for instalation and dries in minutes.
Roy in Oregon
Chris,
Roy in Oregon
