italian job
Hi all, (please excuse me for not too good english) reading the owner manual (1990) there this note:
"switching from NORMAL to the FULL mode setting and to FULL from the NORMAL setting may be done at engine speeds up to 4000 rpm"
Now my questions are:
1 this mean switching from normal to full, or from full to normal above 4000 rpm can be dangerous for the engine?
2 This mean switching from normal to full, or from full to normal above 4000 rpm, will not change the engine mode? So if I switch from normal to full while engine already run at 4500 rpm, engine will continue to run at normal mode also if key is on full position and I will need to wait for engine return again at 4000 rpm then full power will go on automatically?
or...what else?
or...what else?
