Valve Seals
  • Thread starter Thread starter JOE BYRNE
J
JOE BYRNE
I am going to attempt the valve seal thing on my Eldebrock Heads. If I quick dissconect the gauge off my compression gauge and hook up my compressor (same connection) will that work to keep the valves up ??
Yes it will. Haven't done it in a long time but it works perfectly, we used to install Ford valve seals on 283 Chevy valve guides that way.
Bill
Bill,
Just keep pressure in the cylinder...anything else before iI take the spring off to change the seal?? I have read about the rope in the hole but would rather use the compressor
with the air in the cylinder you will need to tap the retainer down to break loose the keepers. a deep 9/16" socket works well.
I will follow your advice. Hope this is easier than the rear spring. Thank you very much
if you have a 4 speed put it in gear and block the wheels to keep the engine from spinning over when you put the air into the cylinder.
It is a 4-speed..its always in reverse but I will block the wheels. Thanks a million.
JOE BYRNE said:
Bill,
Yeah the rope stuff is a little crude, the compressor works good and also the advice of others is right on target as well. Much easier than a rear spring!
Bill
with the compressed air method, its very ez to accidently push the valve off its seat--air goes whoosh and the valve goes "oh sh**....if you feed a few feet of clothesline in thru the sparkplug hole and then roll the piston up with a wrench on the balancer bolt it takes a little longer but is less thrilling
Im going to have to think about what way to go now...the spring was brut force and muscle...this is using my brain a little......been up since 6...will have to sleep on it. Thanks guys
I have done this a number of times but have a valve spring compresser that works really well. I just put air in the cylinder, put the valve spring compressor over the stud, block all holes in the head that can swallow a keeper and remove the spring.
Air in the cylinder does a great job. I actually find working on the head in the car is almost easier then working on the bench.
I think I will go with the air. How much pressure to you keep in...my compressor goes up to 120lbs
I took an old sparkplug, gutted the working parts, drilled out the center of the threaded area where the electrode was, and welded an air connection to it. I then just screw the new homemade Bubba thing into the sparkplug hole, attach the air hose disconnect and fire up the compressor. Works to hold pressure in the cylinder so you can remove springs to replace seals.
Randy
TDC!
Make sure your piston is at Top Dead Center! Putting the car in gear is a good idea, but the auto guys need to ensure they are at TDC. I pull the cap and watch the rotor.
K-D tools makes a real handy prybar that you can lever off the rocker stud to compress the spring. :)
Rick
:w
Randy thanks ever so much. I like the home made Bubba think. You should market it....thanks again.
Rick I will make sure im TDC.....Im just going to take my time with it...god knows I have plenty of time although I did take it out last Sunday...roads were nice and dry and almost 40. Take care
