67BigBlock
- Joined
- Feb 10, 2004
- Messages
- 7
- Location
- Fort Worth, Texas
- Corvette
- 67 Marina Blue 427/435 Coupe, 2001 Silver Z-06
Recently obtained a 67 big block coupe. Nice, straight body driver with a marina blue respray (original color). Only cosmetic flaw externally is that the small hinge on the driver side vent window is broken off where it connects to the chrome of the vent window itself. This causes the window to not seal properly in the closed position, creating a lot of wind noise. I have found replacement hinge parts at Eckler's and also Long Island Corvette. Do I have to take apart the whole vent window assembly to fix the problem or can I somehow glue (JB weld?), or braze a new hinge tab to the vent window so that it will close snug? The window rubber is fresh and if I push the window up to where it should sit, the wind noise goes away.
