Vibration on 2013 Coirvette
robear
New member
Jasper,Alabama
2013 427, 2003 50th Anniversary
Need help with this chronic problem. Found out the other day I have a bent rim in the left rear mag. That is helpful and will replace, but still have front problem. I am going to replace run flats with a set of new Continental Extreme Contact Sport tires. Would like to try new Michelin Pilot Sport 4S but they don't make them in my size for front or rear. Any suggestions or comments on tires on other C6 corvettes. ???
Thanks for your support
Tire Rack shows that the Michelin Super Sport is available in the sizes for the 427 Vert.
If you like to drive year round, the Michelin Pilot AS3+ ZP is available.
Thanks Tuna I was hoping to get away from those run flats. I realize that my low profile tires create a lot of the problems but it’s sorta annoying
One way we, here at the CAC, can help is if you can describe your vibration problem.
