Vin
  • Thread starter Thread starter rmarino57
R
rmarino57
I am looking to purhcase a 1999 Corvette with this VIN 1G1YY22G1X5110644.
I am interested to get a breakdown of what options came with this vehicle.
Bob
Bad news is the VIN won't tell ya which RPO codes came on your car. All it tells your insurance agent is that its a coupe with a LS1 motor 345hp. Your car was number 10644 built of 33270, which was built around the end of Dec. or early Jan. contact the NCM and for a nomial fee ($45 ea.) they will print you out your build sheet and/or window sticker. Good luck
There will be a list of the option codes, paint color, etc stuck in the car. I think it is on the inside of the glove box on the '99. It could also be stuck to the bottom of one of the rear hatch covers.
I looked for a list of codes that would tell you what the RPO codes in the glove compartment mean, but this is all I found. I suspect others will have a better list for you. http://corvetteactioncenter.com/tech/rpo/index.html
Ive passed it on to a friend of mine on another forum.
He will run the VIN thru the dealership database and that should give a full service history and what options it has.
Keep ya posted
Rain
ok
hope some of this is what you want to know:
Rain
VEHICLE INFORMATION
Merchandising Model : 1YY07 Warranty Start Date : 11/30/1998
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : WALTER EARL CHEVROLET, INC.
PO BOX 609
BRIDGEWATER , MA 02324-0609
(508) 697-6000
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
12/05/2001 014594 # V0743 - ECL RELAY HARNESS REPLACE 51791 miles
06/29/2001 006606 # C6871 - COVER AND/OR PAD, FRONT SEAT CUSHION - LEFT - R&R OR REPLA 43725 miles
06/29/2001 006606 # C6870 - COVER AND/OR PAD, FRONT SEAT CUSHION - RIGHT - R&R OR REPL 43725 miles
01/17/2001 052914 # J0690 - PULLEY, ACCESSORY DRIVE BELT IDLER - REPLACE 36118 miles
01/17/2001 052914 # D1322 - MOTOR AND/OR FAN, BLOWER - A/C - R&R OR REPLACE 36118 miles
01/05/2001 052377 # C1012 - WEATHERSTRIP - ROOF - FRONT - ALIGN OR REPLACE 35582 miles
01/05/2001 052379 # J0660 - BELT, SECONDARY ACCESSORY DRIVE - REPLACE 35582 miles
01/05/2001 052379 # J9995 - CUSTOMER CONCERN NOT DUPLICATED 35582 miles
01/05/2001 052379 # N3700 - HOSES, NOZZLES, WASHER AND/OR WIPER STOPS - WINDSHIELD - R 35582 miles
01/05/2001 052379 # Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 35582 miles
12/15/2000 049812 # E7200 - CYLINDER, IGNITION LOCK - R&R OR REPLACE 34669 miles
12/15/2000 049812 # Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 34669 miles
11/28/2000 048948 # J9991 - CUSTOMER CONCERN NOT DUPLICATED 34327 miles
11/28/2000 048948 # V0505 - INSPECT LAP BELT RETRACTORS,INSTALL WEBBING GUIDES 34327 miles
06/27/2000 041061 # L2597 - MUFFLER - DUAL - BOTH - REPLACE 26454 miles
06/27/2000 041061 # R4490 - TRANSMITTER, REMOTE DOOR/REAR COMPARTMENT LOCK - REPLACE 26454 miles
06/27/2000 041061 # H3052 - SHOE, REAR DISC PARKING BRAKE - BOTH - REPLACE 26454 miles
06/27/2000 041061 # H0137 - ROTOR ASSEMBLY - REAR - BOTH - R&R OR REPLACE 26454 miles
06/27/2000 041061 # Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 26454 miles
01/31/2000 033398 # E7125 - TELESCOPIC ACTUATOR, TILT/TELESCOPIC STEERING COLUMN - REP 19684 miles
01/31/2000 033398 # Z7902 - 2-DAY COURTESY TRANSPORTATION 19684 miles
12/07/1999 030870 # H0107 - CALIPER ASSEMBLY - FRONT - BOTH - REPLACE 17001 miles
10/26/1999 028915 # T2020 - TOWING 11600 miles
10/26/1999 028915 # N6360 - INSTRUMENT PANEL RP 11600 miles
10/26/1999 028915 # Z7902 - 2-DAY COURTESY TRANSPORTATION 11600 miles
08/19/1999 025647 # N6278 - EFI WIRING REPAIR 11537 miles
07/08/1999 023515 # C9040 - BELT, SEATBELT RETRACTOR (FRONT) (RIGHT) - REPLACE 9046 miles
06/08/1999 021929 # C9040 - BELT, SEATBELT RETRACTOR (FRONT) (RIGHT) - REPLACE 8000 miles
04/13/1999 019206 # N0225 - HEADLAMP - AIM 5300 miles
04/13/1999 019206 # H2880 - CABLE, PARKING BRAKE - REAR - RIGHT - REPLACE 5300 miles
11/12/1998 033702 # A5541 - CHEMICAL PAINT SPOTTING (HORIZONTAL SURFACES) - BUFFING - 2 miles
11/11/1998 033662 # Z6999 - PDI RELATED FLUID ADDS 5 miles
10/28/1998 A10644 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 1692 kg (3731 lb) Order Number : 095GSC
Build Date : 10/28/1998 Build Plant : 1X5Y - BOWLING GREEN
OPTION CODES
AAB AG2
AK5 AQ9
BGR B34
B84 CC3
CJ2 DL5
DL8 D42
FE3 G90
G92 IL3
JL4 JL9
K63 LS1
MX0 M30
NB6 NG1
NK4 N37
QD4 R9U
T82 T96
UL0 UV6
UV7 UZ6
U1S U52
VL7 V49
V73 XGG
YGH Z51
1AY 1SA
19I 193
86U
Option Codes
I am looking to breakdown the option code list.
