Any C2/C3 Corvette will accept any Chevy small-block or big-block, as they were built that way originally, and all the parts are available to install either engine. The key issue is intake manifold and carburetor height - the taller intake/carburetor combinations require unique hoods. C2 small-blocks all used a flat hood, big-blocks used a raised hood, and the twenty '67 L-88's used the production big-block hood outer panel with a special inner panel with a rear air intake and plenum housing that sealed to the foam ring on the exposed air cleaner base, and the air cleaner element was mounted to the hood.
C3 small-blocks all used a flat hood (except the '70-'72 LT-1, which used a raised big-block hood), big-blocks used a raised hood, and the '68-'69 L-88's used an even higher raised hood.
