L
ltmark
I have had a problem, for some time, with voltage drop when my '85 coupe sits for a week or so. After reading several forum questions, I hooked up my volt meter, in series, with the red battery wire. With doors closed, no accesoreis on, etc., the meter reads 12.89 volts. I read that hooking up a simple test light in the same manner should only show a dull light due to a radio clock, etc. and that the light would brighten if the door was opened, etc. My light was pretty bright with nothing supposedly drawing current. When the door was opened, the light did brighten further.
Question....Should the meter have read 12.89 under the conditions above, or am I not testing correctly? I pulled each fuse, one by one, with both the light and meter, with no change in the voltage reading OR light brightness?
Any help would be appreciated.
