Voltage Reading
  • Thread starter Thread starter Lucky
L
Lucky
Just curious.....what should the VOLTS display read on a 1996 LT1...........Thanks
depends on the state of your battery.
After start it'll jump to 14 to 16, then drop to 13.4.
Upon startup it needs to be a little over 14. At idle with accessories running it may dip into the high 12s (lights, AC, radio, etc), when warm.
Another thing, never trust the in-car gauge, you need to put an external meter on the battery to check it.
Mine is off by .6 V.
