Kid_Again
- Joined
- Jul 6, 2004
- Messages
- 1,171
- Location
- NJ - Which exit you from?
- Corvette
- 65 SB Roadster, 66 BB Coupe
follow VNV's advice, as usual....
...when he was working on the headlight relays for my '66 bb, all he talked about was the need for good grounds on these cars...makes sense and since we had to come home today for a wedding, i figured i would fart around with the '65 sb roadster (which lately, seemed to require more draw on the ammeter (not really an ammeter, it's a shunt device which measures the charging rate of the battery (thanks and a tip 'o da hat to MAD Electronics)) because i had the inclination to check the ground connections...
I should first state that the wiring harnesses on the '65 are new
second, it's now evident to me that the most crucial part of the wiring is the horn relay (thanks to VNV) because it is the power distribution point from the alternator to the entire car...so, i went to tighten up the screw that grounds the horn relay to the radiator support and it stripped right away :eek ...and that's the FIRST, best ground for the system!!!!
, so I spent the entire morning running new ground wires, sanding the mating surfaces clean, soldering all the crimp connectors AND adding dielectric grease...here's what I added:
secured the horn relay with a 1/4x20 bolt and sanded all surfaces before securing and added a second ground at the horn relay to the radiator support
r/r'd existing ground connector on the other side of the radiator support
added a fourth ground on the driver's side of the radiator support for the MSD and ran THAT ground to a new point on the front of the frame
added two grounds from the engine mounts to the frame (one on either side)
added TWO grounds from the dash cluster to the bird cage ( i may extend one of those grounds to the frame)
...took me all morning (with a lift) and what were the results of my efforts?
the ammeter now reads one-half of any reading previously (at any given RPM)
the car now starts RIGHT AWAY whereas i used to have to crank it to start
the lights all around are brighter
...way to go, VNV!!!
...now, I'm taking a bunch of 10ga black wire downa' shore to redo the '66
..a VERY easy fix with spare wire and exisitng connectors
.....i knew that the big problem with the midyear's electrical system was poor grounds but once i saw VNV at work, I knew the correct way to go about it..
![martini :m :m](/data/assets/smilies/martini5.gif)
