Washer pump wiring
hoso
australia
1969 black
Howdy does anyone have a wiring diagram of the washer pump on a 69 , my wipers work fine and i have power showing at the two black wires on the pump cover but nothing works , i feel it may be the washer solenoid [ headlight washer] that is causing a fault , can this be bypassed and can another later tank and seperate pump be wired into the original circuit so it operates thru the switch ??
All comments will be much apreciated
