V
vetdaddy
I noticed the water pump to crank belt on my 1972 454 A/C car was loose.
I have read that this is supposed to be a "direct fit" belt only installed by removing the water pump pulley.
There is a idler pulley next to this belt that is supposed to sit to the outside of the belt but not apply tension to the belt. This pulley seems to function as an outer guide for the belt.
I ordered a replacement belt labeled for my engine with A/C and it is the same size as my original belt that is too loose.
Sooooooo my question:
1. Is the idler pulley in this car designed or intended to tighten the water pump to crank belt? or........
2. Is the idler pulley only designed as an outer guide to the belt offering no tension to the belt?
3. Am I missing something here such as wrong belt sizes? My water pump pulley, crank pulley and idler pulley all appear to be original and stock diameter.
Any help would be greatly appreciated, Scott
