Don Forster
New member
Water Temp Rise 225 during idle/Traffic
You are right! I guess my old school was showing a little bit. Thanks for the reality check.
Depends on what you mean by normal. Do you mean what used to be normal on old style, iron block SB chevy engines, from the 50s to 80s? Or what Chevy designed the system to do with the Gen III small block, with a bottom breathing, low drag sports car? Sure, you can run your fans all the time, and the temps will stay closer to 200 F. Just turn on your AC, and the current system will give you something close to that.
