chevyaddict
Well, I searched the forums and didn't find the answer to this specific question; I'm perplexed.
I replaced the control valve on my 81. No problem - everything works fine EXCEPT that it is leaking ever-so-slightly out of the zerk fitting that points down. Now, my question first is why on earth is there a zerk fitting there (which begs to me to insert grease into it) if there is power steering fluid coming out of it? If I grease it wouldn't that just interject grease into the system which would then mix with the powersteering fluid? Can someone enlighten me??
It looks to be leaking from the little opening where the grease would go into, not from the threads behind it.
Thanks!!
Thanks!!
