What are these parts?
  • Thread starter Thread starter celeryman22
C
celeryman22
What is the terminal by the positive cable? Factory or not? There is a green wire attached but it goes no where.
What is this part?
Does anyone know what this part is? It is a gray,green, white wire with a connector. It runs from the back of the passenger seat where the jack is stored. It isn't attached to anything. the connector was ran to the back of the car.
What are the other items attached to the back of the passenger seat?
Seat Belt Warning Light?
Is there one on passenger seat?
For pic one there is only the one and I assume it is not factory. or pic two Its not hte seat belt warning light it is still connected. This connector was at the back by the rear speakers.
The terminal block is factory but the wire is not. However, this is a great place to make a power connection provided that there is a fuse holder in line. You would be wise to change the wire color to red so everyone will know it is +12v.
The second connector looks like it might be for your power antenna. I will have to check mine to be sure but I am fairly confident.
Thnaks, that would make sense, since it looks like it would reach that far.
On the passenger side in the rear compartment there are some othe connections. I belive one ine the wiper relay or something because sometimes it clicks when the wipers are on.
Any idea what the others are for?
