What are these?
Chetzki
Lake Jackson, TX
1996 Torch Red LT4 Coupe
What are the blue and yellow plastic filter looking bodies under my driver side fuel rail cover? One appears to be a check valve because I can only blow through it in one direction (toward the air intake manifold). What is the recommended replacement interval for these? I'm doing a bunch of PM right now and ran across them tonight. Never noticed it before.
This is an LT4 engine, but probably shared with LT1.
Thanks,
Chetzki
That's a vacuum check valve for the A/C/heater. I don't know if has to do with the cruise control. Anyway, it's usually the culprit when you have a problem with the heater-a/c doors going to the default position. Apparently heat kills em. I think they run about 6 dollars at the dealer.
Torque Shop
Dream Giveaway
