Well this is kind of where I dont know which setup is better. I think going with a slightly milder cam now, with the head work, and the new intake, and maybe just maybe a rotating assembly
would make the car more of a street rat.
From my gathering, a wilder cam will benefit you at a higher RPM, not giving as much low end and torque. If the cam is somewhat milder, the cylinders fill better at a lower engine speed there for making the car have good low end grunt. This is kind of what I have read out of the various books. Most say that for a street car, you want more low to mid torque and hp opposed to high end, because you need to build the motor to produce power in the RPM band it will live in most of the time.
I think the 48 will be fine for now, although I am going to put the 1.6 rockers on. If I need to update I will, if I see a reason to. It isn't that hard to switch.
