Hrtbeat1
Does anyone know where the signal for the shift light comes from? I'm refering to the idiot light along the edge of the display. This is for a '90 auto but I'm sure others are the same.
I recently replaced the D36 rear with 2.59 gears with a D44 with 3.45 gears. I swapped the VSS with one calibrated for the new gears. The speed reads correctly (from what I can tell.) The problem is going down the interstate at 75 mph in OD my shift light comes on :confused I know I'm in OD because I shifted it through all the gears and felt it shift. The car is wanting me to shift again ..... to what, there are no more gears to go to.
I haven't checked the switches in the ECM chip yet. If its there I can change it. I was thinking it may be controlled from the CCM, which I can't reprogram. I guess my alternative is to remove the light bulb itself from behind the display.
Thanks for any input.
ad.
This is driving me batty, but I've been doing my research and I didn't think they exist. If you could look at your Memcal there should be a four letter code on either the chip (inside the blue cover), or on top of the blue cover.
Now I know which ones to order from the dealer. Either one I have to modify so I can put my 'tuned" chip on it. I have to get one for an auto 3.07 rear (close as I can get) and one like yours.
