I'll confess at first I was thinking...hmmm, why wouldn't cross drilled rotors be better, I have them on my sport bike (ZX-12r) so clearly there's a reason, MotoGP uses them.....and so I started looking, sure enough, you're are correct but it looks like slotting helps...they also answered my question on why my motorcycle has them. I don't feel so bad that I just had HD solid rotors put on my Vette, I couldn't afford to go the show and no go route
Pulled this from another forum, and there were others that made the exact claims. Thanks for making me at least question and research a little more.
Crossdrilling your rotors might look neat, but what is it really doing for you? Well, unless your car is using brake pads from the 40's and 50's, not a whole lot. Rotors were first `drilled' because early brake pad materials gave off gasses when heated to racing temperatures - a process known as `gassing out'. These gasses then formed a thin layer between the brake pad face and the rotor, acting as a lubricant and effectively lowering the coefficient of friction. The holes were implemented to give the gasses `somewhere to go'. It was an effective solution, but today's friction materials do not exhibit the same gassing out phenomenon as the early pads.
For this reason, the holes have carried over more as a design feature than a performance feature. Contrary to popular belief they don't lower temperatures (in fact, by removing weight from the rotor, the temperatures can actually increase a little), they create stress risers allowing the rotor to crack sooner, and make a mess of brake pads - sort of like a cheese grater rubbing against them at every stop. (Want more evidence? Look at NASCAR or F1. You would think that if drilling holes in the rotor was the hot ticket, these teams would be doing it.)
The one glaring exception here is in the rare situation where the rotors are so oversized (look at any performance motorcycle or lighter formula car) that the rotors are drilled like Swiss cheese. While the issues of stress risers and brake pad wear are still present, drilling is used to reduce the mass of the parts in spite of these concerns. Remember - nothing comes for free. If these teams switched to non-drilled rotors, they would see lower operating temperatures and longer brake pad life - at the expense of higher weight. It's all about trade-offs.
Slotting
Slotting rotors, on the other hand, might be a consideration if your sanctioning body allows for it. Cutting thin slots across the face of the rotor can actually help to clean the face of the brake pads over time, helping to reduce the `glazing' often found during high-speed use which can lower the coefficient of friction. While there may still be a small concern over creating stress risers in the face of the rotor, if the slots are shallow and cut properly, the trade-off appears to be worth the risk. (Have you looked at a NASCAR rotor lately?)
