Ballpark?
I don't know what mine runs yet. I was looking a another guy's website would had much the same thing and he did a 13.6 the first time, and has improved a little since.
Here is what he/we have.
1974 coupe (I have a 72)
ZZ4 350 (rated at 355hp 460 ft./lbs)
HEI distributor (i still have points)
2 1/2" True dual exaust w/ headers no cats (i have stock manifolds)
Holly 750cfm carb (i have 600cfm)
M21 "close ratio" 4 speed
P24560R15 tires
Naturally I don't know how many seconds the headers and distributor are worth. I'm told the headers are a big deal esspecially when dealing with higher horsepower engines.
GM recomends a 600-750cfm carb.
I am very pleased with this setup. The cars starts everytime, and the driveability is very good. (that is often a problem with high HP engines)
My complains are minor but they are...
The engine doesn't run very smooth in very humid weather. It surges alot. (otherwise it is fine)
Slight "roughness" after 4,000 RPM sometimes. This could easily be due to the 1972 distributor. GM supplies an HEI with the motor, but it won't work with the cable driven tach. Also headers may improve that also.
As for 1/4 mile times.. The 400+ ft/lbs. 4 speed combo makes launching more difficult. But then again too much power is what we call a "GOOD" problem!
One last thing. I bought the GM crate motor so I could avoid this whole issue. They say its 355hp so that saves me a lot of guess work and spares me from being disspointed. I'm probably not getting the whole 355hp since I didn't go with the headers or distributor but thats ok with me.
-Gooney0
