D
Dave C. '04 Z06
K&N and filter lid shouldn't make a difference.
The headers, depending on how well they match your car (how well they are tuned to scavenge), the computer may or may not be able to compensate for it.
I am not too familiar with the older PCM's such as in your '88. I know the newer ones (OBD-I and later) can compensate over time for that stuff to a degree. But the problem is that rarely does someone drive at part throttle at 5000 rpm, so that the computer doesn't know that there is a sweet spot there where the headers are really yanking in that fresh charge. That's where PCM tuning helps alot, because it tells the computer what is expected, so it can calibrate itself better. Also if the headers are scavenging well, you may have to slightly retard your ignition timing to prevent detonation if you're running on the edge. The computer just does what it's told as far as timing is concerned unless the knock sensor triggers. It has no way to measure for optimal timing like it measures for fuel mixture.
-Dave C.
ALSO: as far as someone earlier hoping that someone wasn't taking a shot at Jeff, if refering to me, no..I don't take shots at people. I don't know Jeff, but I'm sure if you guys have respect for him then he does a fine job at tuning PCM's. I'm sure he does the best he can for you. I'm just saying that if you go to McDonald's and ask them who makes the best hamburgers, they're going to say McDonalds. It's business.
-Dave C.
