I think that you'll have to break into the system to replace the switch (#14) The O-ring(#23) seals the switch. In later models, some of these pressure switches use a schrader valve so you can replace it without a drain, but I think you're headed for a freon R&R. Might consider changing to R134 while you're at it! I have used the cheapie kits that has a compatable oil already in the freon, and comes with the new style QD adapters. Probably not the best way, but I've used these kits with great success, and they cost about $30. Consider it for a quick, cheap fix until the system can be converted the right way! Jusy my 2cents.
Jerry
