guido34
It sits right in front of my carb on top of the intake manifold. It looks like some kind of pressure release valve. If you were to remove the bolt that is right under the vacuum line you could pivot it up like a lever. The vacuum line is not hooked up and hasn't been since I've owned it. Someone suggested it might be an EGR valve but it's nowhere near the exhaust and has no visible connection to it. Another suggestion was an older style PCV valve but I've got one on each valve cover. I'd like to remove it permanently because I cannot replace the fuel filter in the carb without removing the carb, this thing is in the way. Thanks in advance!
PS I'd like to include a picture but there is an 83KB limit and I can't seem to make my pictures that small.
