What Is This
rebart
Wisconsin
1981-Black
What is this part called ?? (The plastic part in the middle) Can't can seem to find it in any catalogues. The bottom stem is broken off. If anyone knows where I could pick one up, I would really appreiciate it..
rebart: are you referring to the "air diverter hose" ? See my post "What is this part called " a bit farther down the thread.
Tom
It is the valve in the middle. Two hoses connect to it. One from each manifold. One of the valve stems is broken, so I can't connect the hose from the passenger side manifold.
Looks like the diverter valve; the only one I could find with a quick look was at Zip for a 76; not sure how close it is to the 81, they seem to use the same engine picture for everything....but here is the link...
http://www.zip-products.com/Zip/dep...gine&mscssid=4471F24C7E05444DADF5FEA26A2398FA
I also found a rebuild service for air pump and diverter valve at this paragon link:
http://www.corvette-paragon.com/catalog/category.aspx?cat_id=db4d1312-2034-4022-a9c6-25f591e26398
Hope this helps....dbj
