RedHot85Vette
What Size Wheel Spacers '85 / 16" / 6" BS / 32mm -to- '95 / 17" / 6.9" F & 7.4" R BS 56mm ???
Good Day! I hope all are enjoying a pleasant one.
What Size Wheel Spacers will I need to go from: '85 / 16" (16x8.5 All) / 6" Backspace / 32mm Offset -to- '95 / 17" (17x8.5 Front & 17x9.5 Rear) / 6.9" Front & 7.4" Rear Backspace / 56mm Offset ???
What Size Wheel Spacers do I need to mount 1995 wheels on my 1985? After doing the math (with numbers I got from several reputable sources), I come up with a .9" difference on the front, and a 1.4" difference on the rear. I rounded both up to show that I need 1" Front and 1.5" Rear Spacers.
I don't know what the offset numbers refer to.
If this is correct. please confirm. If Not, then why, and what size would you recommend?
ADDITIONAL INFORMATION
1985 Stock Tires GOODYEAR EAGLE VR 255/50VR-16
1985 Stock Rims, Notes - Turbine style wheel inside surface of turbine blades and center section painted glossy black. Aluminum casting does not shine much when polished.
1995 Stock Tires GOODYEAR EAGLE GS-C 255/45ZR-17 FRONT / 275/40ZR-17 REAR
1995 Stock Rims, Notes - "SAWBLADES" MACHINED FINISH 93-96
Thanks in Advance!
John Proud U. S. Coast Guard Veteran
Thanks in Advance!
