hoosier
Hi all,
I'm working on the rear hub assembly of my 86 and have run into a little problem. I'm trying to remove the hub assembly from the rear knuckle,there are 3 torx bolts that hold the hub in the knuckle, I've tried both 50 and 55 torx bits ,50 is too little and the 55 is too big. I'm not aware of any size in between.
Thanx in advance,
Barry
Thanx in advance,
Barry
