RC81
What will I need to set up the carb? I have a dwell meter but the manual shows other tools needed to make adjustments. I think a Co. called Thexton made them, but I dont know exactly what I need. Thanks in advance.
Thanks. Thats nice of you.If you get the Tomco carb kit, it comes with the gauge to set the lean idle mixture solenoid depth and it also comes with a float gauge which can also be used to set the rich mixture solenoid setting. The only special tool you really need is the one to turn the very small "nut" for the lean and rich solenoid settings with the carb assembled. If you have it apart, you can just use needle nose pliers or a small wrench.
If you are not able to find the carb tools, I can loan you mine.
