IH2LOSE
- Joined
- May 24, 2001
- Messages
- 3,908
- Location
- We Will All Meet Again
- Corvette
- 1966,and a 1962 thats almost complete
Been a while since I have posted, as some of you know I built a 62 with a tubeular chassis running a c4 suspention in it.
Today I went to the last car show of the season here in NY. I put my foot in the car gently on the way to the show and it seams as if as I laid into it it had torque steer from the right rear (this is the side it always come out on if I give it alot of gas) the best way to describe this torque steer is just like if you floor a front wheel drive car but its not as pronounced.it really just very slight.
I have checked all nuts bolts and fastners again.I have checked motor mounts,trans mount,rear diff mounting.I have checked wheels and tire mounting including air pressure.I have checked all welds on the frame,Brakes are all ok none are grabbing. is there any thing in the rear diff that could cause this as the left side is holding back and thats why the right side feels like its steering this way.?? just to double check the rear is sill working I left a hole shot and both marks are the same.
What does a independent rear feel like when its failing
