S
shivelresk
Following changing the control valve for the power steering, I am now experiencing an odd occurance with my steering. When I turn the wheel all the way to the full left lock, a couple inches before the stop the wheel turns over the rest of the way somewhat more quickly. It then takes far more effort to turn it back to the right those few inches before returning to a regular steer. Now when it does this it actually sounds as if it puts a drag on the engine. I've seen no pinched hoses or anything out of normal. I believe that my father had tried removing the large nut on the underside of the car that attatches the pitman arm to the steering box, thinking that was the way to get the control valve off. I had gone to pick up appropriate tools so I wasn't there when this was done, although I had told him that was not the way it came off. Anyway has anyone heard of or experienced anything like this? Could it be possible that something in the steering box was damaged or knocked out of alignment during the process of trying to remove the pitman arm for it? I've heard of a lash adjusting or something, but don't know what that is.
Please any help or ideas would be great. I'm just afraid that it would be very hard to control the car against this effect should I have to turn it that sharply, and going any faster than 5 miles/hour or so, you know just wouldn't want anything to happen to myself, people around me, and lastly the car. Thanks
