I
igasper10
I found a spring-loaded lever of some sort on the right side manifold, just below the Y pipe. Anyone know what this is for???
ian -
ian -
paul79 said:Heat riser control valve.
Enigma said:Paul79 is correct. It is controlled via a temperature switch located usually around the hot coolant return on the intake maifold.
The switch controls the vacuum to the heat riser valve.
While the engine is cold the valve is closed and when the motor is at temp it is open.
Enigma
