hotshotzny
i spent a good portion of the day replacing my old rusty stock exhaust with a new Y pipe and muffler eliminators and was more than pleased with the rumble thye generate..... but
i took it out for a ride and while sitting at a red light i hear a rattle.. so i pop it in n to give it some gas and it stops... as soon as i put it back in gear it pretty much goes away... once i get rolling its totally gone... so i go straight home and put it back up on the lift and have my fatrher look whil ei sit in it with the car in gear and sure enough the heat shield above the cat is ratlleing.. i check itonce it cools down and cant really see where its originating from... i cant figure out why its rattleing now when i never touched that particular piece and it never made a sound before
ad
why on earth would it be doing this... i checked the bolts throughout it and tightened them up and the rattle got a little lighter but it is still there at idle in gear.. pop it in park or N and you can lay right on the gas and not a sound except the rumble of the motor.... and ideas!
adwhy on earth would it be doing this... i checked the bolts throughout it and tightened them up and the rattle got a little lighter but it is still there at idle in gear.. pop it in park or N and you can lay right on the gas and not a sound except the rumble of the motor.... and ideas!
