Hey everyone,
I replaced the master control valve (finally) and it works great.
But now my steering wheel is not aligned with my wheels.
I have to have the wheel turned to about 2 o'clock to drive straight.
How can I re-align the steering wheel to line up with the front wheels?
Thanks everyone!
1.I'd check toe-in on the front!! (1/32-1/16) inch!
I do this by jacking the front of the car up and spinning the wheel and painting a strip around the tire with silver spray paint!
(I use silver because it will ware off quicker than other colors and it's easier to see the line your going to scribe on it!)
2. I have a tire scribe and assume you don't, so take a Brick or Block of Wood and a Ice pick,have someone spin the wheel and scribe a line all the way around the tire evenly so the black rubber line shows all the way around both front tires!!
3. I have Turn Tables and assume you don't, so you need 4 pieces of sheet metal (Aluminum Flashing from Home Depot works good!!) about 1 ft square,2 for each side, apply a little grease between each pair and set them under each tire and let the car down on them, and bounce the front end 4-5 times from the middle of the front! (with ft.wheels strait ahead)
4. Measure at rear of tires from line to line about 3 inches off the floor, and then do the same at the front!! The front should be about 1/32-1/16 Less!
(I use a Tram Gage,but a Tape measure will work)
5.Now,if that is purdy close, in equal amounts shorten the Rt tie rods by turning the collar between the ends!! Same on the left only longer!! (Rt in,Lt out) You said your Steering wheel is at about 2 O'Clock,I'd start with (3/4 turn in Rt), (3/4 turn out Lt) !
