relichunter
What year wheels will fit my 86? I know I'm at 16", but what else will fit, my stock rims are a mess, looking to upgrade to a newer year, Any help?? Thanks
Your pattern is 4.75 x 5 lug and the offset is 56...
so sawblades (38mm) are 18mm closer to the center of the car on each side..
Nothing rubs,.thats too much inside the body and will rub
Other way around
Early cars had 32/ 38mm ( on 9.5" ) offset ; late had 56 mm
Nothing rubs,
a 11" rim with 56mm offset ( or 38mm offset as fitted to the ZR1 's ) fits fine and were fitted by the factory
Just looks wrong because tire is sitting in further than stock position unless the adapter is used to correct
Been on this for a week and have 1 wheel ready for white polish to seal in the finish, and its a sexy looking wheel !
17" x11" A molds fitted to '96 Grand Sport coupes had 50mm offset (7.9" backspacing )The 11" rear wheel fits because it has a 36mm offset but was not offered across the board. That was the ZR-1 rear wheel profile. .
Has anyone ever powdercoated these rims?
Is it possible to powdercoat them?
