After driving my 79 vette and the engine is hot.. It has a tendency to not crank..Turn the key and absolutely nothing happens.. No click, no crank. nothing.. It does start after sitting roughly 15 or so minutes. I assume that it is cooled off a bit... ANY SUGGESTIONS..Thanks Frank
the "click" you (don't) hear is the solenoid terminal putting current through the coil, that then magnetically pulls the starter plunger into the case of the solenoid, in the process pushing the pin that forces the copper washer into contact with the copper lug nut -connected to the positive battery terminal, and with the starter motor connector, all at the same time. if all that works correctly, the mechanical coupling activated by the solenoid pushes the starter clutch/gear into the flywheel as the starter motor turns.
when you don't hear any of the two clicks, the solenoid coil has not been energised, either solenoid defective or start circuit open. (you probably already knew all this.)
in simpler times, the ignition switch sent the voltage to the solenoid with one -usually purple- wire, now I believe it goes to a starter relay, also is in series with the neutral safety switch. of course, VATS on later models.
first thing to check is the neutral switch or clutch switch, also starter relay, if it has one. not familiar with that component, yet. not sure how heat effects this.
last time I had the same symptoms, it was an 82 el camino, and the purple wire was high resistance at the solenoid terminal, loose and corroded. if you could get to the solenoid, you could apply a jumper (or screwdriver) from the battery cable end at the starter to the solenoid terminal. if it activates solenoid, the supply circuit is open. if it does not, solenoid is defective, open wire, whatever.
narrows it down, but no solution.
