vettegirl said:
			Oh, good to know they don't all have competition mode - that was worrying me (so what's new!).  I would bet this problem is just me not knowing what is normal for the car (yet again)!
Hi Lauren--
Competition Mode is only applicable if your Vette has Active Handling. Active Handling is a "98 1/2" option, so you very well might not have it. The button on your console will be labeled "Active Handling" if your Vette is so equipped. Otherwise, it just has the Traction Control icon on it.
As for your power-lacking problem, I'm not sure what to say there. If everything else seems to run okay, and you only have trouble when you try to burn a little rubber, then you might have something wrong with the torque management system in the computer. Actually, it might not technically be a problem. I don't fully understand it, but I think that the torque management system will intervene even if you have Traction Control off under some circumstances, to prevent you from damaging the powertrain. Perhaps c4c5 could add a little insight here...
One more thought-- although you have an automatic and I had/will have a manual, I noticed on mine that even with TC off, I could still experience problems launching if I didn't manipulate the throttle correctly. If I revved to about 2000 RPM, but let off the clutch as the RPMs were descending, then tried to hammer it, I'd bog the clutch down and wouldn't even chirp the tires. But if I made sure I was holding the RPMs steady or slightly increasing, I could start like I intended (quickly with a little bit of wheelspin). I wonder what would happen if you try to start off with aggressive, yet partial throttle. In other words, don't mash the pedal all the way down. If torque management is responding negatively to your WOT, then maybe partial throttle can give you the results you want.
			You guys must be getting really sick of me
What we're sick of is the fact that your problem won't go away so you can enjoy your Vette! Seriously, everybody (okay,
almost everybody) comes here to get their questions answered and problems solved, so I don't see how anybody would be getting sick of you.
 I've been helped numerous times, so I'm sure I speak for everyone else when I say we just want to help you get your problem solved.
Good luck,
Fred
