vettebob
1987 Corvette.
Been a mechanic for 40 years, but I am having trouble with this one.
My Corvette will hold a 17 lb. radiator pressure test for hours without dropping even 1/2 lb. and not a drop of water leaks out anywhere.
However, the car may run fine and hold water for weeks, and make long desert trips without overheating nor losing water. But every once and a while the low coolant light will come on, and I find the car anywhere from a quart to a gallon low on water.
It is on it's second new radiator cap, the overflow tank never gets too full, cooling system has been flushed and tested, it has a new 180 thermostat, etc. and as I said, with 17 lbs. of pressure on the cooling system it sat on concrete for several hours without a single drop of water leaking out.
Where and how the hell is it losing water sometimes??
Thanks,
vettebob
Thanks,
vettebob
