No, the vacuum gets "lower." Go back to your high school physics. "For every reaction, there is an opposite and equal reaction." Nature always wants to return to 14.7 PSI. So, say you suck a milk shake through a straw. It will take more vacuum to pull the shake up the straw. You'll suck so hard, you collapse the straw. Thus pulling the vacuum under 14.7 PSI. Release it and the straw will most likely return to it's normal shape... i.e. 14.7 PSI. So the faster the engine speed, the more the vacuum pulls (a lower pressure) on the diaphram inside the distributor advance. Just thought I'd throw that in to make it more understandable with the straw and shake analogy.
