Where to buy dimmer actuator for C3 ?
Manu79c3
Australia
Hi all, the steering column was in bits when i bought the car, and i now know the actuator between turn lever pivot and dimmer rod is missing.
Has Anyone got any idea where i can buy one from?? Thanks everybody!
Close, thanks Bill ! The part I'm after sits higher up in the column, i need the plastic part that pushes on the dimmer rod, it dits behind the plastic cover near the lrvers on the column. The link uou orovided takes me to yhe switvh itself - u less i got it wrong? Cheers manu
What at year is your car? Does it have a tilt-telescoping steering wheel?
It's a 1979 coupe, with tilt and telescopic column. I have found a picture of the actuator on the net but nobody seems to have a listing for it. Any suggestions appreciated :-)
Thank you all very much for your help and advice, i managed to source the parts i needed on ebay and us websires. My steering column is now back together in its correct setup, and headlight wiring is back to standard; no more foot operated dimmer switch!😊
