Pa Goose said:If you are running in the summer months I would use the higher octane to prevent spark knock and 87 the other 9 months
snk1994 said:Now the question is...Empty tank to store the car during the winter months or full? Mine has always been full with a fuel stabolizer (stabol) for storage.
Timing's on, it's also controlled pretty much by the computer :eyeroleBob Chadwick said:Have you checked your timing recently?
I have a 77 with the distributor advanced to put in 36 degrees at 3,200 rpm and it never pings on regular.
HammerDown said:Being my cars a low compression engine and only about some 200HP the only thing I can think of that's causing the dreaded ping is maybe some carbon hot spots in the combustion chamber. The ping can be a real issue in the summer months when I put the AC on. Just that little extra load on the engine really brings on the ping:ugh
Went ahead and warmed the engine, unplugged the distributir/computer multi plug...and put a light on it. Base timing at idle was 8 degrees. So I backed it even further down to 5 degrees, still a slight ping with the AC on under load.ruby76 said:Double check your timing, it could be the culprit of your ping under acceleration.
