MaineShark
- Joined
- Sep 21, 2002
- Messages
- 1,326
- Location
- Rockingham County, NH
- Corvette
- 1979 L82, 1987 Buick Grand National
I'm currently thinking about putting in an overdrive transmission, and debating between the 700-R4 and the 200-4R.
The 700-R4 would work very well with my stock rear-end ratio, which is a good thing, because it requires a new crossmember and modifications to the drive shaft to fit, which costs a decent amount of money.
The 200-4R would not work well with my stock ratio, but it bolts in with little expense, meaning I'd have enough left over to buy new rear gears. That would give me a new transmission, and new rear gears. So, I'll probably go this way.
To look at the ratios:
With my current rear gearing (3.55:1), the overall ratios for the 700-R4 are 10.86:1 in first, 5.75:1 in second, 3.55:1 in third, and 2.49:1 in fourth.
With 3.90:1 rear gearing, the overall ratios with the 200-4R are 10.69:1 in first, 6.12:1 in second, 3.9:1 in third, and 2.61:1 in fourth.
So, the 200-4R will not give me quite as good of a first gear (high number is better) or as good of a fourth gear (low number is better), but the first gear will be within 2%, and the fourth gear difference will only amount to 100 rpms at 70mph. The 200-4R will have more aggressive second and third gears, though, which should help with in-town driving.
Alternately, I could go with 3.73:1 rear gears with the 200-4R, and get 10.22:1, 5.86:1, 3.73:1, and 2.50:1. So, I would have essentially the same gear in fourth, but first gear would not be as good (over 6% difference between this setup and the 700-R4), although second and third would still be more agressive than the 700-R4.
So, my real debate is which 200-4R setup to go with, not between the 700-R4 and the 200-4R.
Thoughts?
Joe
Thoughts?
Joe
